I had running problems on my '71 that were fuel related. A rebuild of the carb (not the original but a Quadrajet that had been fitted from a later car) and a lot of faffing about didn't sort things out, so in desperation I bought a professionally rebuilt Quad' - of the correct year - from a dealer in the States and after some rejetting to compensate for the deviations of my car from stock, the car now runs perfectly.John - there are USA specialists who offer re-manufactured Quadrajets - they ain't cheap (especially when adding the shipping costs etc) but unless you swap the inlet manifold and use a 'square bore' carb (which again ain't cheap) - or - source a Holley spreadbore carb to match your existing inlet you're kinda stuffed. Quadrajets are great carbs when working properly.
Those carbs listed on Amazon are not genuine Rochester Quadrajets but Chinese knock-off 'compatibles' - which is why they're cheap. I'm not saying they're necessarily inferior but as ever, you get what you pay for.Some of those carbs on Amazon look surprisingly cheap...........
Try a gravity fed slave tank?A bit of a disappointment today. Went to a car meet with my son and all was well on the way there, but on the way back I've got the same symptoms again. Ticks over fine, goes if I floor it, but feels like it's running on less than 8 cylinders at part throttle. I guess I need to strip and clean the carb again, but the question is why? I did fit a new filter after the last episode, I'm thinking maybe it's water in my fuel.
Could be, I did have a problem a couple of years ago with the carb mounting bolts coming loose, but then I'd expect the tickover to drop. I'll check they are tight and if so I'll try cleaning the carb out again. Trouble is even if that cures the problem it will presumably just happen again at some point.I’m wondering if there’s a vacuum leak.
I'm going to need a fairly large tank to get to Wednesday's meeting RossTry a gravity fed slave tank?
Could be the carb base or manifold isn’t flat. Piece of float glass and some emery.Could be, I did have a problem a couple of years ago with the carb mounting bolts coming loose, but then I'd expect the tickover to drop. I'll check they are tight and if so I'll try cleaning the carb out again. Trouble is even if that cures the problem it will presumably just happen again at some point.
