Just been looking to buy an additive for my 72. My question is, Can it hurt to put vspe in the fuel even though being a rebuilt engine I probably dont need the lead for valve seat protection but can buy multishot container so more cost effective. Or would folk just suggest the Eps. ThanksChris, maybe you could ship a case of VSP over here before you travel - you could make up the box with some of Liz's luggage - that way freeing up all that space in the back!
Hmmm when I built my beach buggy 4 years ago i renewed all fuel pipes with gates ethanlol proof pipes and have never had any problems, though I make sure i run it up every 3/4 weeks through the winter. The vette has been body off restored 6 years ago with all new pipes , lines and hoses, the previous owner has run it since then with I presume no problems, so maybe all is well. But as a new owner you feel you want to do the best you can to avoid problems arising. So do we assume that All additives, are a bit of a con and therefore unnecesary.? I’m talking diesel injector cleaner, egr / maf sensor cleaner, and a host of other available things. I wonder if owners that have been using an ethanol protection and have not had any issues would suddenly stop using it . I guess its down to each to their own and what they feel comfortable with. Personally i dont think it will do any harm with the bonus that it may help, still not sure which one to buy thoI'm not totally convinced about all this additive being added to 'modern' fuels - wondering if its simply down to the Ethanol content in the fuel 'finding-out' leaks, degrading seals, gaskets and other plastic/rubber items before the 'ordinary' petrol. Perhaps a problem was going to occur anyway and the Ethanol make it occur earlier?. My experience is that when supposedly Ethanol related issues happen - when subsequently addressed with currently available an 'correct' OEM rated replacements the 'issue' goes away. Reminds me of the major issues unleaded fuels were going to cause us - everyone was in panic. "my engine is going to be ruined" etc etc - the problems didn't really materialise did they? OK so a few 'A' series powered cars like older Mini's and Moggy Minor's suffered knackered-out valves, but they were most likely knackered-out before using un-leaded fuel. Sensible folk simply 'knocked-back' ignition timing a couple of degrees and life continued much as before - as it will after Ethanol........
I might have felt the same way, were I not familiar with the race team experience at Le Mans. When they came over some years ago (C5R era I think), they found that the fuel supplied by the ACO had a high ethanol content. It took only a day or so to "corrode" the fuel system on the cars. They had to redesign the fuel system completely to run the ACO fuel. Later of course, high E content became the norm in WEC and IMSA racing, so everyone has to run E compatible systems now.I'm not totally convinced about all this additive being added to 'modern' fuels - wondering if its simply down to the Ethanol content in the fuel 'finding-out' leaks, degrading seals, gaskets and other plastic/rubber items before the 'ordinary' petrol. Perhaps a problem was going to occur anyway and the Ethanol make it occur earlier?. My experience is that when supposedly Ethanol related issues happen - when subsequently addressed with currently available an 'correct' OEM rated replacements the 'issue' goes away. Reminds me of the major issues unleaded fuels were going to cause us - everyone was in panic. "my engine is going to be ruined" etc etc - the problems didn't really materialise did they? OK so a few 'A' series powered cars like older Mini's and Moggy Minor's suffered knackered-out valves, but they were most likely knackered-out before using un-leaded fuel. Sensible folk simply 'knocked-back' ignition timing a couple of degrees and life continued much as before - as it will after Ethanol........
Thanks for that, opie oils have eps so will get som in the vette and the buggy tooI might have felt the same way, were I not familiar with the race team experience at Le Mans. When they came over some years ago (C5R era I think), they found that the fuel supplied by the ACO had a high ethanol content. It took only a day or so to "corrode" the fuel system on the cars. They had to redesign the fuel system completely to run the ACO fuel. Later of course, high E content became the norm in WEC and IMSA racing, so everyone has to run E compatible systems now.
Interestingly our current "metal" car a Skoda, was new in 2016. At the time of buying I asked about E fuel, assuming the dealer would say it was OK. But no, while it is possible to use it, Skoda do not recommend using E fuel if at all possible. So, I don't.
The Corvette has a neoprene type lining in the fuel tank (from '78 on they all do), so I'm certainly not risking it with that. The FBHVC did run extensive tests on additives, coming from teh viewpoint that they may not work, or be necessary. But they found conclusivley that EPS worked.
I don't see it would do any harm, but if you don't need the octane boosted, then I'd stick with EPS. That's what I did. That said, I have been occasionally putting 98 fuel in the car if the station doesn't have non E 95. I've found that as the timing on mine is slightly "aggressive", it does seem to prefer it! However, at the moment its cheaper to add 98 and EPS than use 95 and VSPe!
Probably some top secret establishment that produces 105 Octane fuel for Corvettes using boiled pigs blood , bat wings and a liberal sprinkling of moon dustI was looking at a map the other day (annoying I can't recall what area I was looking at) saw a site title 'Synthetic fuel manufacturing and refining plant' - wonder what that was all about?
Is the eps a fuel stabiliser as well as an ethanol protector? Saw some millers espv in halfords today and that doesnt say its a stabiliser. Ie stops gum and varnish from stale fuel.Probably some top secret establishment that produces 105 Octane fuel for Corvettes using boiled pigs blood , bat wings and a liberal sprinkling of moon dust
By the way , I have just bitten the bullet and ordered a job lot of EPS direct from Millers ( worked out cheaper than Amazon UK even with their free delivery ) . I will soon have so many bottles in the back of the C3 , I will look like a boot leg booze runner !
So why do BP websites state that BP Ultimate contains no ethanol except in the south west of the UK ? Is this more Fake News ??????I did a survey of fuel companies a short while ago and the only one that confirmed that their premium fuel didn't have ethanol was Esso. Even though when you use the pump it says E5 on the nozzle. All the others said it contained ethanol. Consequently I now only use Esso Supreme.
Good news , is that nationwide? As i read except devon and cornwall but the other post states texaco but not cornwall or devon?! This is becoming a lot of hearsay and misinformation. I have a local esso garage but dont know if it has or has not. Any more clarification much appreciated.I did a survey of fuel companies a short while ago and the only one that confirmed that their premium fuel didn't have ethanol was Esso. Even though when you use the pump it says E5 on the nozzle. All the others said it contained ethanol. Consequently I now only use Esso Supreme.
