curious bystander
Perhaps somebody that understands this problem should do an article for Vette News to warn all those members who are oblivious to the potential hazard this stuff is causing?
Ross you are on againPerhaps somebody that understands this problem should do an article for Vette News to warn all those members who are oblivious to the potential hazard this stuff is causing?
I am thinking of going over to a Pratt and Witney Turbine - The Aviation Industry do not allow allow Ethanol near their engines - I usually have to test my Vette on a Runway anyway!I think I am gonna convert my C3 to steam power . Maybe four cylinders and Walschaerts Valve gear . Then it can run on water all day long !![]()
It's also linked with brake fluid. Dot 3 and Dot 4 mineral brake fluid has the same issue. Its hygroscopic also and will absorb moisture from condensation in the braking system. A major issue (as we all know) for earlier Vettes. The moisture also causes any cast steel/iron braking components to rust and contaminate the brake fluid just to make things even worse. The boiling point of the brake fluid is lowered by the moisture absorbed by the brake fluid - result is brake fade (and ultimately internal corrosion of the ferrous parts of the braking system).Perhaps somebody that understands this problem should do an article for Vette News to warn all those members who are oblivious to the potential hazard this stuff is causing?
According to a mate of mine with a pilots license , they don`t use WD40 either as that ultimately becomes hygroscopic with age after applied . Or something along those linesI am thinking of going over to a Pratt and Witney Turbine - The Aviation Industry do not allow allow Ethanol near their engines - I usually have to test my Vette on a Runway anyway!
I think our colleagues across the pond refer to this as 'percolation' - fine, except there isn't a cup of coffee as an end result.Thank you Ross the water in Ethanol lowers the boiling temp of the Fuel and hence causes early vaporization - hot day, hot drive, switch the engine off and then a little later she does not want to start - one of our Members Chris, has built an Ethanol cooler for his C2 for precisely this problem - Genius!
Actually Ross it is called premature Vaporization (do not ask me how I know)I think our colleagues across the pond refer to this as 'percolation' - fine, except there isn't a cup of coffee as an end result.
I was getting fuel vapourisation on my little 327 and it was causing driving issues and hot start issues. Driving wise I was losing power and it just didn't feel happy and hesitant to accelerate. Starting from hot was a bugger too. Chatted to a few people about it, as I didn't know at the time, and realised it was fuel vapourisation / percolation. Now I've fitted a phenolic spacer between my inlet manifold and the carb. Mine is only a thin one at about 0.4 of an inch thick - but it does the job really well. I needed a thin one due to bonnet clearance issues. In hindsight I could have gone thicker as I have a bit more space than I thought once everything was tightened down.
Now the car drives better, and I no longer hear the fuel bubbling away in the engine bay after I've stopped the engine. The carb itself is also MUCH cooler to the touch than before.
True indeed. I try to stave it off by only using super unleaded too.The issue increase as the rate of Ethanol in our fuel increases
I think you will find that there 5% ethanol in our petrol now no matter what octane rating .True indeed. I try to stave it off by only using super unleaded too.
I read somewhere that Esso only sell Ethanol free petrol in a few areas of the UK . Absurd if you ask me ! Why not supply it to all their stations ? Probably all down to the logistics of where the refineries are located that omit the damned stuff !Can anyone confirm that Esso do not supply fuel with Ethanol - in all UK service stations.
Indeed. But in the future they are planning on upping normal unleaded to a lot more ethanol, whilst keeping the super unleaded at 5% as the protection grade. Could be worse though, in other countries they already have a far higher % of ethanol in their fuels.I think you will find that there 5% ethanol in our petrol now no matter what octane rating .
