Tim from the photo it looks like the pump doesn't have a return to tank line, is that right?Ive got an as new pump here. Not sure if there’s different types by year, off my 69
Thanks for that Andy, two top tips in one thread!I’ll give you another tip John....When you go to fit the new pump you will find that the actuator rod keeps dropping down out of the block before you can get the pumps actuating arm located under it. On the front end of the block, adacent to the pump you will find a bolt head. Remove this short bolt. It’s thread in the block goes right through to the actuator so temporarily insert a longer bolt here to touch onto the rod and hey presto it holds it up while you fit the pump.
Yes it does, shame.No it doesn’t, I’m guessing yours does then.
Just don`t stand near any naked flames for a while .I got around to changing my fuel pump today thanks to all the excellent advice I got here
Gavin was right about where the old one was leaking from
I needed to move the brass fitting from the old to the new pump. It is a taper thread and I went with Ross' suggestion of PTFE tape to seal it.
Andy's tip about locking the pushrod worked perfectly.
Tim's idea of clamping the rubber pipe with the correct tool also did the job (I have to say though that my tool is much more shiny than Tim's)
Following Ross' advice I did take care selecting the new pump and I can confirm that for a 78 the Delphi pump from Rockauto fits perfectly.
Finally, whilst I couldn't follow Chuffer's advice about taping up my sleeves as I had a T shirt on, he was right I do now stink of petrol!
Thanks everyone.
Just don`t stand near any naked flames for a while .![]()
Been out on the high seas on a classic sailing ship , so brace yourselves land lubbers , I`m back and raring to go !Chuffers back!!.. its been a bit quieter on here for a while now.
Been out on the high seas on a classic sailing ship , so brace yourselves land lubbers , I`m back and raring to go !![]()
It`s called a close reach dear boy . But if the wind should vear away I might jibe and catch you unawares !Abandon all hope of steering a straight course through any threads, were going to be tacking against the wind from here on.![]()
Not so much a sailor , more like a press ganged deck hand .A sailor ouit in our midst eh!![]()
But if the wind should vear away I might jibe and catch you unawares !![]()
No ! that`s your department .Is that the same as a cheap jibe?![]()
I see you haven`t quiet `nd down while I have been away !!!!What i need now is a witty, intelligent, grown up response..
heres the best i could do..
