You need to consider what type of fire system you want
A system where there are nozzles pipped into the engine bay and the cabin area
Type that is automatic triggered
A hand pulled cable as the trigger
Or a simple unit like I have in my C5 which is mounted to a harness bar
I replace mine like every 5 years if needed to or not
Then need to consider where it could be mounted but also easy to get to quickly
The size you select might not fit where you want it, so consider location first and then match the size of unit
Most types are real cheap, works for vehicle and like kitchen fires
Get one that has a gauge on it that tells if fully charged or reports it needs to be replaced
and the mount has a quick way to release the unit from the mount
