Hi all , some may have been reading about my missing bearing support bolt that rattled out . I have been losing oil through the bolt hole. I have been keeping the oil level full and using sparingly. My query is and hoping for some opinions on is that I read that the muncie 4 speed does not have a front seal on the mainshaft but a slinger that throws the oil back int the box. I also read that if the box is over filled then oil will escape into and drip out of the bellhousing. I notice that if i fill til the oil runs out of the level plughole then it seems to chuck a lot of oil out initially and then once the level has dropped to a half inch below the fill hole then it seems to lose oil at a much slower rate. I think i have been losing more oil because i have been over filling. I am now still checking after every run but only topping up to a half inch below plughole. I am finding that the level is not dropping half as much as it did when filled right up to overflowing.
Any thoughts appreciated , tia ps i will at some time be pulling the trans to sddress the missing bolt.
