“When I pull the box to the rear will the splined front shaft just pull out of the spigot bush , through the clutch and release bearing without disturbing the bell housing clutch fork.?”
Yes, it’ll stay on the ball pivot but will drop a bit. When you put the box back you just have to make sure the input shaft goes back through the release bearing.
You might not even move it far enough back for the input shaft to come all the way out of the clutch if you just want to get to the bolt.
Thanks oneball, I have a mechanic friend coming one eve next week and we are going to have a go at it , he came for a look last eve. Iwill get the prop snd slip yoke off andthe shifter console and lever off ready. The reverse lock out cablelooks tight between box and tunnel but hope fully it is just the reverse lever end to detatch and a bracket to the trans., looks like an electrical switch on the box too that is linked to the reverse lever? And speedo cable. Trans mount bolts and exhaust hanger. ( I think i can leave exhausts in situ and just support them in the crossmember holes.
Any tips for detatching and replacing shift rods to their original positions would be helpful. Or anything else you can suggest. I am hoping i can replace the bolt in the bearing support using the existing gasket but depending on how it looks we will decide whether to pull the box right out.
Nervous but excited at the prospect of being able to drive further than the few local miles i have been without having to constantly top up the oil
Thanks for all the help and advice
