Be careful of going much more than 8” long bolts because the ends may hang lower than the wheel rim - would not be good if one had a puncture.
Yes , i had read that, also someone said to have rhe excess at the top but dont know if that makes a difference. I will re measure mine as i read standard ones were six inches . Sure mine were over seven. . May take a picture to see what people think . Thanks allBe careful of going much more than 8” long bolts because the ends may hang lower than the wheel rim - would not be good if one had a puncture.
Yes , i had read that, also someone said to have rhe excess at the top but dont know if that makes a difference. I will re measure mine as i read standard ones were six inches . Sure mine were over seven. . May take a picture to see what people think . Thanks all![]()
Yes pretty much perfect.Pic would be good.
I reckon this is just right. A little bit of rake and not too low especially at the rear.
And this is too high
Thanks, the front is slightly lower than the rear at present, whether the new glass rear leaf is holding the rear higher, I think the front springs were not renewed when car was done 6 years ago. Lowering the rear i can see altering the rake at the front but not sure it can physically raise the front could itIf you are lowering the rear that will raise the front, you need to have the chassis set up correctly first with the front slightly lower than the back etc and then look at the body, you need it to drive correctly
Yes - the balance of the weight is shiftingThanks, the front is slightly lower than the rear at present, whether the new glass rear leaf is holding the rear higher, I think the front springs were not renewed when car was done 6 years ago. Lowering the rear i can see altering the rake at the front but not sure it can physically raise the front could it![]()
Anyone got any pics of a c3 with some neg camber at rear or of smart struts fitted , thanksAh ! That looks like the way to go , thank you all. , I will invrstigate the smart strutrods![]()
Gold star for Antijam. Rose brothers came up with both the Rose joint and the machine that wraps Roses chocolates (named after the machine).
Who was "Heim" then??
The term "smart" relates to the modified bracket (to lower the inboard mounting point), rather than the strut rods themselves.
Oneball, it looks like you have retained the stock bracket? Is that for regulatory reasons?
Cheers, Andy
Thanks Oneball, it's interesting to get your take on the smart-strut bracket. You have to assume GM had their reasoning behind the stock design. Smart struts are marketed to make a "big improvement to rear end stability" but I wonder if the theory is bourne out more on a road car with softer springs and more suspension travel.Not convinced by them. But I’ve not looked at what they affect exactly only heard the blurb.
You don’t want the upper and lower links the same as you want camber change with suspension movement to keep the wheel level as you corner. I’ve not seen any race car with the bottom mount you described.
