Update 8(?)
Over a long Easter break, I thought i’d try to figure out what my priority list should be. Now that Yvette runs nicely and quietly (despite my personal preferences), she’s street safe and MOT-able (if my insurance wants it), she’ll light my way home and she’s water tight.
So, now it’s time to start on the things that
should work but don’t
need to work. Starting point for that are all the dials. So I know that a lot of people would consider them essential, however other than the speedo everything else is just good to have.
Rev-counter is an obvious fix, if not particularly easy on the wallet. The replacement crate engine has a bog standard HEI distributor without the mechanical drive for the cable fitting from the Rev-counter. So replace the distributor right? At £200ish that’s a purchase for another payday. Except that, on a punt, I searched on eBay for ‘Chevrolet HEI tach’ and came up with a new HEI with a mechanical tech drive from the states for £60 delivered. It remains to be seen if it was a bargain or a mistake.
Fuel level is a bit of a ‘mystery’. As I’ve never had enough fuel in it to get the float to lift, I’m not certain if it works either way. I started looking at level senders and comparing with what I have in the tank (you never know what I might have in this car). Turns out it’s a standard tank (in pretty good nick) with a standard sender, who would have thought it!
View media item 319Checking the underside I can see that the wiring is a little ‘lashed in’ but should be function-able.
View media item 320View media item 318So I fish up the float with a bit of wire and a torch and presto, a working fuel gauge! NEXT!
Temperature gauge is interesting. I have 2 in fact. The original is disconnected, I found that out when I had the dash board out doing the indicators. However the replacement is an unpowered ‘mechanical’ gauge attached to somewhere on the drivers side cylinder head
So, I need to figure out where the original pickup would be for the original temperature sensor and wire that in. I may keep the extra sensor but move it to the oil pan or the transmission fluid?
Oil pressure is the real headache. For the life of me, I can’t see or find where the pressure pickup should be. Any photos or pointers for that would be great.
