Guage goes back to zero when you switch engine off.Could it be that your oil pressure gauge is getting stuck at 35psi?
Thanks for the offer Johng, I'll sort something this end, I used to have a couple of oil gauges for work, unfortunately all that kit went back when I packed in. Typical.I have an old Smiths capillary type oil pressure gauge that you can have if you like, to check if the problem is the gauge or in your engine (can't guarantee it still works though, must be 40 years old!). Alternatively you can buy an electric type gauge with sensor for £20 on ebay, plus you might need a thread adapter to fit it in your block
Are you talking about the 'pick-up' tube with the 'strainer'/gauze on the underside? - if so it 100% has to be a tight fit in the oil pump. It also need checking for its position in relation to the base of the oil pan. Too close and there is a risk of oil starvation - too far away and the same thing applies if running with a low oil level and corning hard.Any one know how to get a new oil strainer on a new oil pump, been struggling all morning, I know there supposed to be a tight fit but ridiculously difficult, any cheats ?
