My container internal width is 93"What is internal width of standard container?
Through flow mechanical ventilation is a possible answer - fan one end - vent the other. Fan powered 24/7.Metal Containers sweat in the sun - you need air flow - trust me I had a load of Chrome Fixtures that I have had to Junk and now also the Container
Ross should be "Fan powered 4/27"Through flow mechanical ventilation is a possible answer - fan one end - vent the other. Fan powered 24/7.
Barry - you are so 'adroit' wiv dem words -Ross should be "Fan powered 4/27"
Thanks DanHi.
If you need any help with insurance at all then please feel free to drop me a line.
Regards,
Dan.
Yes had mine in a regular garage for 27 years until it was recently sold. It just fitted in but it was not possible to get into the passenger door and the drivers door was a bit of a squeeze but possible.
Do as Chuffer suggests for gauging length of vehicle - if width is 'tight' (and you're happy to access car from passenger door) then use an additional tennis ball (or same one re-aligned with l/h side of windscreen frame) to place the car as far to the left as possible.A good tip for parking your pride and joy in a tight garage is to suspend a tennis ball on a length of string from a roof truss at the point where it touches the windscreen with a bit of clearance between the nose and the wall if driving in forwards , or rear screen if reversing in . Much more user friendly than a bit of carpet fixed to the wall . No damage to bodywork if you get it wrong !![]()
OK if you have manual wind up windows , but if power windows you will be hard pressed to reach in to the centre console switch ! Or have to leave window open .Another tip: When you can only open the door a limited amount it is five thousand million times easier to get in and out with the window down and the roof off.
Thanks for those details. Its interesting to see that a shipping container is bigger than my current council garage I have to park my C3 in (1968) until the solicitors pull their fingers out and I can finally move house.Internal width of container is 2350 mm. So 2" under 8'. Chrome bumper Vette is 1758 mm wide (69"). So it will fit but you'll probably need to step out of T Roof (rather than door) or push/pull the car in. No different to many local authority lock-ups - I've used 8' wide lock-ups before with other American cars.
