Replacement Radiator
I installed a Dewitt with built in electric fan along side the normal engine fan. The electric fan is virtually hidden behind the fan cowl but you have the best of both worlds and it never went over normal all this summer.
Wow I'm surprised you can fit both fans in. Any problems fitting the rad?
Andrew Gorrod
No not really the fan is quite slim and the rad has cowls welded on to the rad. Fitting was fine with plenty of clearance. it was on my 68 with a steel fan cowl. I have attached a few photos showing work in progress.
Different to '68 big block shroud too.....suspect that steel shroud is for lo po engine options as it seems to block part of the radiator?
images
