Hope you don't mind me jumping in on your thread and I know you now have new plug leads but if anyone else is in the market for new leads I have just purchased spiral wound plug leads for my Chevy C10 from Anglo Classic Car Parts Ltd and they are amazing, when I started up after fitting them I had to reduce the idle speed as the leads were so much better than the old ones, and the old ones weren't actually old. I did a lot of reading before purchasing these leads and unlike the normal carbon leads which have a high resistance to provide supression from interference these have a low resistance which works well with the resistor plugs which are the only ones readily available these days. I bought 8 metres which was plenty for my HEI distributor with coil in cap if you have the seperate coil type there was plenty left over for a coil lead. I bought the cable and crimped my ends on myself so I could run the leads the way I wanted them. I have no connection with this company other than as a satisfied customer and I'm sure similar cables are available from other suppliers.
Graham
