Thanks for that, not having a User manual that's nice to know.The pull down is a vacuum switch to raise the headlights without switching on the lights. The other looks like it's after market.
Thanks for that info, I tried it with ignition on and cannot see the effect. I'll see if I can trace the wiring!What Bill says . The "fill panel" that both pull switch and the aftermarket item are fitted to can be removed (the pull switch will have small vacuum hoses attached), so you can maybe see what wire colours to look for on the aftermarket switch circuit. Or, take chance and switch it to see what happens!
I'd say antenna cutoff, stop antenna going up, for use with aux, iPod etc. I've fitted similarMaybe an over ride switch for an electric radiator fan? (if fitted) Or to raise/lower the electric radio antenna if there is a non original stereo fitted?
Ah!.....I'll try that as the aerial doesn't extend when the radio is switched on although it appears to work!...another little job I was getting around to! No electric fan on mine, just the standard clutched one. ThanksI'd say antenna cutoff, stop antenna going up, for use with aux, iPod etc. I've fitted similar
The sixth digit on the vin is the year. I believe this is correct,Steven, thanks. Will get a copy...not totally sure whether she's a '79 or '80. I have the Haynes manual
Thanks. Car had a new chassis 1986 and carries a Californian Department of Motor Vehicles issued VIN which does not conform with ‘Vette norm!The sixth digit on the vin is the year. I believe this is correct,
8=1978
9=1979
A=1980.
Oh sorry, not much help then! LOL !Thanks. Car had a new chassis 1986 and carries a Californian Department of Motor Vehicles issued VIN which does not conform with ‘Vette norm!
Basing my assumptions on it being declared as “first registered on 1/1/1979” on import and body/lights spec. DVLA have granted it ‘historic’Oh sorry, not much help then! LOL !
Excellent, no RFL, you can de- MOT it as well, although seems most people prefer to have one for peace of mind & also future selling value.Basing my assumptions on it being declared as “first registered on 1/1/1979” on import and body/lights spec. DVLA have granted it ‘historic’
