My December 1979 built 1980 model year has the differences Daytona Vette mentions . VIN is 1Z878AS411094 . Ironically mine also has that same little illuminated rocker switch adjascent to headlight vacuum release plunger . I always thought it to be an aftermarket job and it never did anything . Probably because it had no connections to it
. Never thought it could have controlled much as it is only about a 5 amp switch . I can see the possibility of an aerial switch though as my electric aerial has never worked but that`s no major problem as don`t use the after market CD Radio as the original speakers are puny and exhaust too loud man
The cut out for that switch now houses an after market toggle switch with its own dedicated wiring and in line fused supply that I fitted for a new washer pump and overcoming an earth / wiring fault I could never trace so gave up ! At least I now have a powerfull squirt for as long as I want
