Actually the Heinkel He 178 kicked it all off followed by the Heinkel 268 but was not a success and ultimately lead to the ME 262 .
That`s a scary statistic ! Even though the much later Lockheed XF-104 was branded `The Widow Maker` due to the number of crashes . It was apparently inherently unstable due to design although very fast . Basically a rocket with a pilot in it .I came across the book How Meteors Hit the Ground, by Geoffrey Higges, a few years ago. The accident rate for Meteors was astonishing. Between 1945 and 1957 almost 800 (yes, eight hundred) Meteors were written off and close to 400 pilots were killed. The worst year was 1952 when on average a Meteor pilot was killed every four days. These numbers really are incredible. Maximum respect to people who flew Meteors and survived.
Another fascinating book is The Quick and the Dead, by former Gloster Chief Test Pilot Bill Waterton. Hard to believe the battles he had with Gloster designers to make the Javelin fit for service. They seemed to be reluctant to accept that anything they had designed could possibly need changing or improving.
Chris Sale
'64 Coupe
Actually the Heinkel 178 ( first image )
Here is one even uglier !! The Mescherscmitt ME 163 Komet . It looks like a pregnant gold fishThat Heinkel 178 is a bit of an ugly bugger. Thanks for the info Chuffer , always thought the Messerschmitt was the first.
There are horror stories of things going badly wrong with leaking fuel making physical contact with the pilot or ground crew and and those affected actually having body parts or whole bodies completely dissolved.Here is one even uglier !! The Mescherscmitt ME 163 Komet . It looks like a pregnant gold fishI was fascinated by all these early aircraft like most boys mad about planes back in the day . It was the only rocket powered fighter aircraft in history and the only piloted aircraft to exceed 1000 kilometres / hour in level flight at the time . It first flew in 1941 but was of limited use as it had a flight time of just 7.5 minutes and then had to glide to land . Further development was knocked on the head by the Nazi`s as the Allies progressed further across Europe .View attachment 29474
Arguably Britain would have been well in front of Germany relating jet propulsion if the extremely staid and backwards thinking Air Ministry and RAF top brass actually 'recognised' the genius of Frank Whittle....as it was we were really lucky that he still obstinately pursued his prototypes and proved his designs.That Heinkel 178 is a bit of an ugly bugger. Thanks for the info Chuffer , always thought the Messerschmitt was the first.
I seem to remember they used that plane in a Star Trek enterprise time travel storyline where it dropped a A bomb on New York and the Nazi’s took over some of the US .Here is one even uglier !! The Mescherscmitt ME 163 Komet . It looks like a pregnant gold fishI was fascinated by all these early aircraft like most boys mad about planes back in the day . It was the only rocket powered fighter aircraft in history and the only piloted aircraft to exceed 1000 kilometres / hour in level flight at the time . It first flew in 1941 but was of limited use as it had a flight time of just 7.5 minutes and then had to glide to land . Further development was knocked on the head by the Nazi`s as the Allies progressed further across Europe .View attachment 29474
By gad sir ! If it was good enough for Waterloo it`s good enough now don`t you know !Arguably Britain would have been well in front of Germany relating jet propulsion if the extremely staid and backwards thinking Air Ministry and RAF top brass actually 'recognised' the genius of Frank Whittle....as it was we were really lucky that he still obstinately pursued his prototypes and proved his designs.
That 'clouded' vision 'mindset' of Army top brass in the early days of WW1 could also be blamed for useful deployment of aircraft being held back in favour of horse borne warfare, ultimately created a far longer and protracted conflict.
It certainly was a exceptional aircraft Chuffer - I should know since I actually flew it!.....Well, perhaps not quite; in 1965 or 66 (I can't remember the exact year) I was allowed to 'fly' the terrain following flight simulator built for TSR2 by BAC. Even that was quite an experience!Here`s one that should never have been allowed to get away : the BAC TSR-2 . One fabulous aircraft way ahead of its time and would have given the RAF a world beating View attachment 29471aircraft for years to come . Only one prototype built and flew on 27th September 1964 . It had conventional and nuclear capability , a Mach 2 cruising speed and Mach 1.1 at only 200 feet above ground level . Typical British politics killed it off !!
Read up on the Komet Chuffer it's fascinating reading. Attrition rate of pilots was far, far higher than even front line conventional fighter pilots. Komets could explode for no reason either in the air or on the ground taking out ground crew.
Great experiences and memories .It certainly was a exceptional aircraft Chuffer - I should know since I actually flew it!.....Well, perhaps not quite; in 1965 or 66 (I can't remember the exact year) I was allowed to 'fly' the terrain following flight simulator built for TSR2 by BAC. Even that was quite an experience!
There were in fact three aircraft built. One of the two survivors resides in the Royal Air Force Museum at Cosford.
View attachment 29480View attachment 29481
Part of the aircraft's advanced avionics.
My 'flight' in TSR2 was part of a memorable week. In the same week I also met Barnes Wallis of 'Bouncing Bomb' fame. Although almost 80 he still had a working office at BAC Weybridge Division. A quite remarkable man.
All sounds about right to me Ross . I knew it had a rate of climb superior to anything else at the time .In its day as an 'interceptor' it was fully capable of taking-off, immediately climbing vertically, and on its way up to its (always unclassified) service ceiling accelerating up past Mach 1 in the vertical climb.
I seem to recall reports following organised 'war game manouvers' with the USAF where Lightnings 'surprised' 'Dragon Lady' U2 'spy plane's in level flight and 'unreachable' by most other fighter aircraft (with their lower service ceilings) and the Lightnings still climbing vertically up through and past the U2's cruise altitude 60000 or so feet and continuing up past them to a reported 70000 ft or so. But with missile technology improving significantly 'interceptor' aircraft became redundant and the Lightning didn't have a long enough range to be deployed for other duties.......as I understand. Someone correct any inaccuracies?
