I'd like to buy a PCM flashing tool and have access to this software - Where can I get it from?![]()
If you're serious in doing more with the electronics in vehicles of the last 30 years, you need at least 2 tools
1. OBD-II full scanner and recorder
Works best with a laptop that has MS Windows but also has an APP to work on a cellphone
This scanner uses Bluetooth, so laptop and cellphone have to have BT
OBDLINK MX+ is the scanner, about $140 US
Tools to make changes to GM calibrations for PCM and TCM are not cheap, not many vendors make and sell them as fricking governments hate people doing changes that affect smog laws
I have been doing custom tuning since 1995, you cannot go to any school and learn how to do this and this means you cannot buy a tuning tool and become a pro in doing so and many times people screw their vehicles up using the vehicle as a learning process
IF your interest is having a tool that does not allow you doing the tuning but have someone like me do the custom tunes, and you use a tuning flash only tool, than here is the tool you want
This would allow for you or anyone who comes to you with a GM gas based engine from like 1996 to abut present
Simply you would use the scanner, in record mode and drive the vehicle and scanner collect engine and tranny data,
that become a recording file, can be played back later or emailed to like me to analyze and know that exactly what changes to make in the tune
You then need this tool
On the left, select the "OBDII Dealer Kit"
You're buying this from that vendor, not me
It is not cheap, they do ship to the UK
This comes with cables, hardware interface (plugs into the DLC under the dash) and software
With this tool and your laptop, it allows you to read the PCM or TCM, it becomes a file that you email to me
I then do all the tuning, email the new tune, and you use that tool to program that into the controllers and you're done
Most case if totally stock vehicle a custom tune will increase flywheel HP by 30 and higher torque from low to upper RPMs and gain fuel mileage
