I presume it is a small block otherwise springs for coilovers should be 550lbs - Coilovers at the rear not needed - best is a good Steel Spring Heavy duty if you want and single adjust shocks (same as the front)Yes the height issue is the same both sides of the rear. On the front whilst trying to fit the fender flares I discovered the driver side is about an inch higher than the passenger side so I figured might as well just replace the lot with semi coil overs rather than deal with cutting worn old springs and all the associated hassle of getting both sides level. Have ordered Van Steel coils for the front. I would love to have coil overs on the rear but i'm already way over my original 20 grand budget and can't justify rears at the moment but definitely going to think about it for the future.
I'm based in East London and have been meaning to join the club for ages and never got round to it, will get it sorted now you've mentioned it. With any luck being a member will help with insurance quotes as i've not had much luck so far, I think being 24 isn't helping!
East London - Get yourself to some of the Club Meets
Vettes are great and so is the Club - Look forward to you joining
Loads of Help and camaraderie
