And the relevance is ?Does anyone else have a military sticker on their windscreen?
A novel approach !!!I would practise 'kerb hugging' in a RHD car and leaning to the centre of the car with left arm resting on centre console....helps to judge things from a different perspective perhaps.....
Coolness.And the relevance is ?
Not sure what model it was, the standard grand Cherokee had a 5.2 motor, they then put the 5.9L magnum V8 in the grand Cherokee limited. It was a 1998 model and produced I think for only one year. It was the for runner of the SRT version fastest SUV produced at the time.Which model was that ? the WK model V8 has the 5.7 Hemi and the SRT version had a 6.1 . Later model Grand Cherokee SRT`s were 6.4 litre I believe . I have a WK 5.7 Litre with upgraded induction . Lovely induction noise when you give it the beans and surprises quite a few people with it acceleartion as it`s a bit of Q car . It is RHD and my daily driver . As you say , one quick Jeep and I love it . Puts a smile on my face when not driving the Vette .
The mind boggles ! Does you new toy have a military sticker ? If so are you sure you haven`t bought a Sherman tank by mistake !Coolness.
I guessed it must have been a limited edition US market only with those engine variants . The 2005 to 2010 UK spec Grand Cherokee Hemi 5.7 was up there with the Porche Cayenne S at the time for performance and came with serious off roading capabilities rather than a ponced up Soccer Mom`s runabout that would shy away from a muddy puddle . Plus it has a proper V8 .Not sure what model it was, the standard grand Cherokee had a 5.2 motor, they then put the 5.9L magnum V8 in the grand Cherokee limited. It was a 1998 model and produced I think for only one year. It was the for runner of the SRT version fastest SUV produced at the time.
Definitely sounds like a tank so I'm half way there.The mind boggles ! Does you new toy have a military sticker ? If so are you sure you haven`t bought a Sherman tank by mistake !
Can`t wait until you`re all the way there then .Definitely sounds like a tank so I'm half way there.
I think you are missing the point here ! No one is giving you crap so calm down !What's with the "windscreen" crap ?
No not on the windshield but I do have other Military decals and if anyone gives me crap having it on
they would need teeth work
Glad you got the price down to a reasonable value. And at least I now know where to go if I need my Vette's gearbox refurbishedI got the insurance down quite a lot and it will drop almost half next year but I refurbish gearboxes as my side income so that will cover it. Need to tinker with it this weekend so it idles right. Very awesome.
Had a look on the old nett, they did do it for Europe as well, but that didn’t include one for us in RHD. They were all LHD. He bought it through Clive Sutton, and it was the first one imported into the UK. It’s still going strong in Israel.I guessed it must have been a limited edition US market only with those engine variants . The 2005 to 2010 UK spec Grand Cherokee Hemi 5.7 was up there with the Porche Cayenne S at the time for performance and came with serious off roading capabilities rather than a ponced up Soccer Mom`s runabout that would shy away from a muddy puddle . Plus it has a proper V8 .
Grand Cherokees do seem to go on for evere if maintained properly .Had a look on the old nett, they did do it for Europe as well, but that didn’t include one for us in RHD. They were all LHD. He bought it through Clive Sutton, and it was the first one imported into the UK. It’s still going strong in Israel.
If you find you need a 3/4” rear, I have a brand new one from Van Steel, sent to me in error (No bushes though)I reckon my rear one is about the same.
In the few weeks after acquiring my '71 I religiously changed all the cars fluids - engine oil, brake fluid, Differential lubricant, coolant and screenwash - but for some reason not the gearbox oil. Three years on it seems prudent to rectify this. Part of the reason for the delay was that I was unsure whether my transmission, that should be a four speed Muncie, had both drain and filler plugs or just a filler. On some Muncies the drain plug boss on the casting is left untapped.
So it's up on the ramps and and a crawl underneath that happily reveals I have both filler and drain plugs....
Filler arrowed yellow, drain red. The plastic tube intruding into the top of the pic is what I will be using to refill the box.
While under the car it seems a good time to check whether I have a date correct box and even if it is indeed a Muncie. The serial number stamped on the casing is P1D13A. P indicates a Muncie (Muncie Plant) 1 refers to 1971, D to the fourth month, April, 13 the date and A shows it is a standard wide ratio 4-speed - which is what it should be. The most accurate build date I can find for my car is April 17th so an assembly date of April 13th for the transmission would suggest I probably have the original box.
I removed the plugs - the filler first, because if I remove the drain and find out the filler is immovable, I'm up a certain creek with out a paddle! Fortunately both unscrew easily and while the oil is draining I immerse the bottle containing its replacement in hot water to lower the viscosity which should make refilling easier.
Both the filler and drain plugs are the magnetic type and seem to have picked up very little swarf over the years - and certainly no broken teeth!
With the old oil drained I replace the drain plug (wrapped with PTFE tape), insert my plastic tube into the filler hole....
......and up in the engine bay, attach the other end to the spout on the oil bottle, securing it with a Ty-Rap.
With steady squeezes on the bottle and occasional releases of air to let it regain its shape I discharge the whole litre into the box......which only just overfills.
With the filler plug refitted - also with a PTFE wrap - that's another job ticked off!
That may be the case on mine too. There are a series of characters stamped on the same boss as the transmission serial number but unfortunately too small for me to read.Im sure my box has the chassis number stamped on it.
