Vet68
Hi there. I took the wheels off of my Grand Sport last year. They are huge and it can be awkward to take them off and put them on again without catching the brake disc or calipers.
A solution I see are wheel alignment pins. So, you remove the top two wheel nuts after lifting the car, screw the pins onto the hub, through the wheel. Then when you are ready, remove the other wheel nuts and slide the wheel carefully off. Putting the wheels back is reverse, all done without wheel versus brake contact.
I searched for such pins in the UK but could not find any. The majority are make ended, when the Corvette C6 and C7 need female, and probably too short to be of use at around 15cm.
I'm thinking of getting a local CNC company to machine some to my design, so they fit the hubs correctly and are long enough. I would go for stainless steel.
I was wondering if anyone knows of suitable pins that may be available in the UK (you can buy such pins from ACS in the USA but they are £80 before shipping and taxes)?
Alternatively, is there interest from the Corvette community if I get a batch made up?
I know there may be other solutions that people use, like wrapping the caliper and disc with cloths)... but that is not the question I am asking here.
Just want to make our lives a little easier with a quality product, designed to do a particular job, and made by a UK company.
With thanks.
Bryan
With thanks.
Bryan
