Don't, it can harm the paint due to trapping moisturecan anyone recomend a good c3 waterproof full cover for outdoor use
Seen several cars with microblister problems after being stored underneath covers outside. Certain days with rapid temperature changes are the worst for Condensation with pints and pints of water forming on the car, combined with the cover whipping the paintwork in the wind , not a good scenario. . I have even seen condensation on my vehicles in an airchamber on a couple of frosty days when the sun has come out and rapidly warmed the garage. Normally the moving air within the chamber keeps the condensation from forming on the cold surfaces but sometimes even the chamber cant cope. A separate insulated room within the larger garage seems the best solution , or a heated integral garage ajoining the houseDon't, it can harm the paint due to trapping moisture
trouble is , a micro blister is a lack of adhesion between the paint and the substrate . Once it has blistered it cant just re stick itself, the bond is broken it either stays as a blister which may eventually break off leaving a spot with no paint, or at best swell with heat and then shrink back when cools but it is still not attached to the primer or gel so is on borrowed time. Glass cars can still have blistering issues even having never been under a cover. Mine has a few and these are from poor prep, and the PO just sanding back the paint instead of strippinback to glassfibre . This has left a few blisters but also lots of shrinkage around repairs and feathering of different paint layers. Will one day hope to strip and repaint properly. Probably when I finally find a short bb hoodMine's been 10 years under Stormforce 4 layer covers. They last about 3 years before they need replacing. As mentioned one or two areas rub through but overall it's much better than leaving the car in the open if you don't have access to shelter. Any micro blistering dries out in the spring/ summer I find.Stormforce Car Covers | Fully Waterproof & Breathable | Coverzone
Official Manufacturer of Stormforce Covers. Our best selling covers are high quality & custom made in the UK for year round protection of your vehicle.www.cover-zone.com
Likewise on mine too . Only very minute blistering mostly on front wing tops and shows up most under fluorescent lights .Seen several cars with microblister problems after being stored underneath covers outside. Certain days with rapid temperature changes are the worst for Condensation with pints and pints of water forming on the car, combined with the cover whipping the paintwork in the wind , not a good scenario. . I have even seen condensation on my vehicles in an airchamber on a couple of frosty days when the sun has come out and rapidly warmed the garage. Normally the moving air within the chamber keeps the condensation from forming on the cold surfaces but sometimes even the chamber cant cope. A separate insulated room within the larger garage seems the best solution , or a heated integral garage ajoining the house
The worse thing is chuffer, once you have seen one on yr vette , you can Never unsee it !🫣Likewise on mine too . Only very minute blistering mostly on front wing tops and shows up most under fluorescent lights .
Very true !!!The worse thing is chuffer, once you have seen one on yr vette , you can Never unsee it !🫣
Oh yes !Your first mark on your new paintwork is always the worst.
