Having only had my C4 a few days I am still in the new car anxiety stage.
I took the car out this evening and when I got back I left it idling for a bit, the engine temp rose to the point where the fans kicked in fairly quickly. A quick Google suggests this is fairly normal for the C4 and LT1 as they do run hot. So is this OK?
Also, the car seems to be idling about 600rpm when fully warmed up. Is this a bit low? If I hold the revs at 1000rpm in neutral the car gets a bit "shakey". It is fine as you move past that point. When driving I am not getting any hesitation or signs of miss firing. Normal or not?
