VIN Number 1G1AY0780E5108713
Sorry I forgot to show this
Description | Position | Raw Data | Decoded Data |
Region: | 1 | 1 | North America |
Country: | 1-2 | 1G | U.S.A. |
Manufacturer: | 2-3 | G1 | Chevrolet |
Model Specific: | 4-8 | AY078 | Unknown |
Check Digit: | 9 | 0 | Valid |
Year: | 10 | E | 1984 |
Assembly Plant: | 11 | 5 | 5 |
Serial Number: | 12-17 | 108713 | 108713 |
Nothing in the car's history shows as for Europe, but maybe just did not keep stats for outside USA
Vehicle Specifications
year | 1984 | make | Chevrolet |
model | Corvette | trim | Base |
style | Hatchback | type | Hatchback |
size | | category | Sports Car |
made_in | United States | made_in_city | BOWLING GREEN |
doors | 2-Door | fuel_type | Regular |
fuel_capacity | | city_mileage | |
highway_mileage | | engine | 5.7-L V-8 OHV 16V |
engine_size | 5.7 | engine_size_units | |
engine_cylinders | 8 | transmission | |
transmission_type | | transmission_speeds | |
drivetrain | Rear-Wheel Drive | anti_brake_system | |
steering_type | | curb_weight | |
gross_vehicle_weight_rating | | overall_height | |
overall_length | | overall_width | |
wheelbase_length | | standard_seating | |
invoice_price | | delivery_charges | |
Recalls & Defects
Recall Subject: Seat Belts:front:anchorage
Report Receipt Date: 09/04/1991
NHTSA Campaign: 91v143000
Summary
Under certain vehicle operations and occupant usage conditions, the safety belts can lock up or jam in the safety belt retractor.
Consequence
If lockup occurs, it is impossible to pull the belt out of the retractor. The occupant of a seat with an unusable safety belt is subject to increased risk of injury or death in the event of a sudden stop or accident.
Remedy
Replace the safety belts if the lockup occurs.
Notes
System: safety belts. Vehicle description: passenger cars.
Recall Subject: Vehicle Speed Control
Report Receipt Date: 03/19/1985
NHTSA Campaign: 85v029000
Summary
The cruise control vacuum solenoid valves may malfunction at any time the engine is running, and the cruise control is engaged and cause unexpected engine acceleration. Consequence of defect: loss of accelerator control could result in a vehicle crash without prior warning.
Remedy
Install and relocate a new cruise control servo assembly.
Notes
Vehicle description: passenger cars equipped with rpo k34 cruise control. System: cruise control.
Recall Subject: Power Train:drive line: differential Unit
Report Receipt Date: 10/01/1985
NHTSA Campaign: 85v118000
Summary
Cars may lose the wire snap rings that hold the differential cross shaft in position in the rear axle differential case assembly, allowing the shaft to move. Consequence of defect: the cross shaft movement could cause the shaft to contact the carrier or pinion teeth, possibly locking up the rear wheels and result in a crash without prior warning.
Remedy
Install a rear axle differential cross shaft retaining kit.
Notes
System: rear axle. Vehicle description: passenger cars with 3.07 axle and f41 suspension.
Recall Subject: Electrical System:12v/24v/48v Battery:cables
Report Receipt Date: 08/25/1983
NHTSA Campaign: 83v081000
Summary
The insulation of the battery cable, because of its position, rubs against some of the engine wiring components. once the insulation is worn through, the battery could rapidly discharge.
Remedy
The dealer will install a new engine harness retainer bracket, protective conduit, cable clips, a cable tie strap and will reposition the terminals on the ground stud on all involved vehicles.
Notes
Vehicle description: passenger vehicles.system: electrical; battery cable insulation. Consequences of defect: the headlights would cease to function, due to loss of battery power; driving at night, in fog or other severe weather conditions could result in an accident.
Recall Subject: Service Brakes, Hydraulic:foundation Components:disc:caliper
Report Receipt Date: 07/07/1983
NHTSA Campaign: 83v064000
Summary
Attaching bolts were mistakenly coated with a slippery material during production. This material will act as a lubricant and bolts may loosen and eventually fall off.
Remedy
Dealer will install new caliper bracket bolts free of charge.
Notes
Vehicle description: passenger vehicles.system: service brakes; front brake caliper bracket to steering knuckle attaching bolt. Consequences of defect: the front brake assembly could become partially separated from the knuckle assembly, causing the wheel to lock. Loss of vehicle control without prior warning and an accident could result.
Recall Subject: Equipment
Report Receipt Date: 10/24/2007
NHTSA Campaign: 07e088000
Summary
Certain Honeywell fram racing brand hp4 and hp8 oil filters that were manufactured from May 25, 2006, through September 14, 2007, and sold for use as replacement equipment for vehicles list above. The affected filters are marked with a date code a61451 through a72571 sequentially. The date code and part number appear on the filter housing. fram racing hp4 and hp8 oil filters not bearing a date code in this range are not affected by this recall. The gasket of the oil filter becomes more pliable under high temperatures and pressures.
Consequence
This condition may cause inadequate sealing and loss of engine oil, possibly resulting in a fire.
Remedy
Honeywell will replace the affected oil filters free of charge. The recall began during November 2007. Owners can contact fram customer service toll-free at 1-800-890-2075.
Market Value
Below Market Price | $6542.21 |
Average Market Price | $8866.65 |
Above Market Price | $11191.09 |
