Headlight motor
Is the motor bad or simply needs a gear replacement ?
Is the motor getting voltage and ground, maybe a relay issue, wiring or connector pins
Full motor units
Steven Smith
I think the 3 wire motor was only used between 1984 and 1987.
if you can't get one can the motor be removed and rebuilt ?
Do both motors spin the same way, in which case a left hand motor course fitted onto the "gearbox".
Claremont has a left hand one.
