Help with finding some C4 parts
Nails84
Hi All
Please can I ask for some help finding the right parts for my manual 1992 C4 LT1?
While my radiator is currently doing it's job, it's seen better days and could do with replacing. Looking at rock auto, I have 2 options:
Which one should I go for, and should I also order a new radiator cap while I am at it? Or is there some other brand of radiator I should be considering? Also, what coolant and how much do it need please?
Also, would anyone be able to help me source new centre caps for my 1992 alloys? I can't see them on Rock Auto.
Also looking for rear numberplate reflector as one of mine is letting condensation in. Any ideas where I can get these?
Sorry for all the questions and thank you.
No real C4 knowledge so can’t help with your rad. But might be worth speaking to Keith at Eurovettes.
Hi All
Rock auto's are only really any good for routine service items and stuff like steering and suspension stuff - not so good for Vette specific items. You could try Adrian Dromey on eBay - he always has cars for sale and used parts. He goes under the id of "I own a shelby" - this link will get you there - eBay item number:155128461104
For one, you need to select type as if the car has an auto tranny or not
Auto would have cooling lines going to one side's end cap of radiator
If auto than next question are the cooling lines going to left or right side of radiator
From that, then look at the radiators you're looking at if they have the cooling line connections
and on the correct side
This would be a good time to determine if the 2 coolant hoses from the engine be replaced and the pressure cap
IF the 2 you show were both the same size, the first one is far cheaper cost could also mean it has less volume for
coolant flow and will cause coolant temps to run hotter in the summer, so the best case is a higher flow model
All the specialist corvette suppliers in the US would be able to supply the necessary parts for your C4.
Ecklers, corvette central, Zip, Paragon, to name a few.
