Hi all, while at a little car show last week I went to leave and my starter for the first time in my ownership, failed to engage fully and just mashed against the ring gear , couldnt have happened in a worse place as loads of people milling around 🫣. It was fine when re tried immeadiately afterward. I have read that the starters suffer from heat soak and fail sometimes. Any opinions on if this is a symptom. I will check for loose bolts or cables. I noticed when I removed it in the past that it had been shimmed with thin plastic type card I guess to align it.?
What are the mini starters that I have seen comments about as an improvement on the gm big ones. TiA
