Krusty
Yup... I'm back... with ANOTHER oil leak on the 2001 C5
After a few months off the road whilst the weather is bad and I've been messing around with my other cars and motorcycles, I've come to my C5 to put it back on the road for April 1st only to find my entire sump is soaked with engine oil
I noticed it around 2 weeks ago when I had my car elevated off the ground whilst I was cleaning my brakes, also checking, cleaning, regreasing and retorque'ing various components (steering and suspension related). I glanced under the car and noticed my entire oil pan was covered in engine oil!
The car hasn't been off my driveway for over 4 months and I know it was dry when I parked it up. So I cleaned all the oil off the lower pan (I believe its called a bat wing?), I came to it tonight just to start the car up as I have been doing every 2 weeks to keep the motor good and battery charged... before starting I checked and noticed its completely wet again! (even though the car has not moved anywhere).
A quick look with my inspection camera behind the alternator, it looks like the upper oil pan could be the issue. I just want to know if it really is an involved job as I've read online? if it is then I'm going to have to take it to a shop for it to be done.
I'm so annoyed at the car! it seems every time I come to it, it has another leak! only 65.8k miles and I've already replaced the valve cover gaskets, the oil pressure switch, the valley cover gasket, the front timing cover and gasket including main seal whilst it was off and the PCV piping. ALL of which have been the cause of oil leaks in the last 2 years of ownership.
I'm starting to debate selling the car again, its becoming a 'never meet your childhood hero' scenario! not once have I came to this car and it hasn't give me an issue of some description
Any insight on the job and if it can be done at home, would be a great help. Cheers
