Just to wrap up this item then here are a few pics from the (somewhat extensive) rebuild of the passenger side birdcage sill. Having done quite a bit of research to find appropriate bits of metal to replace the rusted areas I found that a 50mm square of 2.5mm thick (12 gauge) steel tube has the same cross section radius as the birdcage sill. That saved a huge amount of work in getting the right section.
So that meant I just had to cut out the right shape from the tube and then fit in the right place...
A lot of the holes that are in sill needed to be drilled as I had replaced the metal where they were located. so using the glassfibre sill cover as a template I was able to drill those through.
... and after a lot of cutting, welding and grinding (repeated seemingly for ever) I have ended up with ....
I have left out the (considerable) effort required to keep this sill straight. Warping and distortion inevitably occurred with so much welding and I got used to working in small sections, very slowly and then checking the straightness and fit quite often so that I could tell when things went awry. Sometimes the distortion didn't seem to take full effect until quite a bit later - I suppose the metal has to work out the internal stresses caused by the heat and this takes a little while.
However the 'finished' (there is still some finishing work to do) sill fits really well - nice and straight on the body mounts. It's a little rough in places but its really strong and rigid. When I took it off the car I could twist the sill about 30degrees in each direction with very little effort.
I still need to fit the safety belt guide plate (see on the right in the last pic and below clamped in place) but that's relatively straight forward. When the sill is on the bench anyway....
The hinge post joins to the sill with one of these (I still have to cut out the hole for the #2 body mount bolt):
And those familiar with the birdcage will know what this is...
Next steps are to refurbish the rear of the sill to the birdcage door striker panel area, then fit the sill, the hinge post and the lower windscreen corner back on the car, (probably) rivet each piece in place temporarily, check everything at least 100 times and then once more, and then weld everything in place. Then the other side......
