A biy of an update since my last post was just more tedious washing off of thick layers of grease and grime from the inner frames with copious amounts of parrafin , rags and scrapers scrapers to get down to a clean surface that can then be needle gunned to remove all old paint , rust and scale to give a sound bare steel finish ready to be painted with primer , undercoat and two coats of ` red paint . All brush applied of course , but a lot more needle gunning and linishing before we get to the paint stage . I am sure I will have a severe case of `white finger ` by then as I have only just got over all the hand vibration from the compressed air needle gun after 5 hours at it yesterday !
Whilst all this boring stuff carries on I thought it might be of interest to back track a bit ( no pun intended ) on more technical work carried out before I started this post . The very heavy connecting rods that take the power drive from the pistons to the centre driving wheels via a crank had been taken off ( seen lying on the ground in photo ) together with the coupling rods which transfer the drive from the centre driven wheels to the leading and trailing pairs of driving wheels . All six driving wheels are 6 feet 7 inches diameter . The pistons were removed from the two 20 .5 inch bore x 28 inch stroke cylinders together with the long stroke piston valves that that provide inlet and exhaust steam into the cylinders via the valve ports that run round the periphery of the steam chest as can be seen in the last photo . The valve and piston bore liners will be machined out and new liners shrunk fitted using liquid nitrogen and the machined in situ to correct tolerences with new valve and piston rings . The valve gear is of Walschaerts piston valve design that was widely adopted throughout British steam locomotive design and indeed much of the world . I will go into more detail on that in a future update .
Memo to ones self - must make time to finish off the odd jobs on the C3 and a service oil and filter change too !
