Ahhh🫶
! The heady smell of a two stroke in the morning !
It could be a number of things causing the `grit ` in the exhaust . Coal quality as you say because decent quality is getting hard to come by . The latest fad is e -coal that is brickettes that has about 30% bio fuel additives that are bonded with the coal with a form of glue . As you suggested one loco in particular did it , it could also just be that the fireman was shovelling in a lot of coal dust that settles out of the coal in the tender . That would get drawn straight up the boiler tubes and out the chimney by the draught . Could also be caused by the bolier tubes due for cleaning of soot and ash which is routine maintenance . Another possibility is that the smokebox was not properly cleaned out after the previous day in service . The char that collects there can then get drawn up the chimney by the exhaust blast from the cylinders , especially if no spark arrester has been fitted.Also question for Chuffer:
When the steam engine is producing a lot of grit in its smoke, what does that mean - is it poor quality coal, not hot enough, too hot? Reason why I ask is because I had a rover ticket to roam the line and went on a few engines, but one of them was very gritty and it came in through all the open windows landing on table etc. You put your hand out of the window and you could feel you hand gently getting shot blasted by grit. Couldn't put your head out on that train, you'd go blind (unless you had googles on). Went on that train early in the morning, and later in the day, and it was doing it all the time. The others were fine.
I am on hols in North Wales for two weeks so may pay a visit to one of the narrow gauge railways although been to them all several times .Thanks Chuffer for the explanation.
That photo was taken near the end of the day / one of the last train runs. It gritted first thing in the morning with a full load when I first got there. Still, lovely engine though.Not a demanding load then . The bunker looks almost empty so the fireman was probably digging around in lots of coal dust and the bottom of the bunker .
