And why?Is that a new spring? How much did you shorten it?
And why?
Interesting - my 18" rears are on 9" wide rim with 5" (rather than 4") inset (keeping F/R track the same as stock). Ends etc of the 7 leaf spring fit comfortably inside the wheel rim (sway bar linkage didn't - have removed it) didn't need to use an offset trailing arm with the 18" rims - however with a 285/40 rear tyre having quite a 'square' section as such it does 'kiss' the chassis very lightly when cornering hard as the trailing arm or stock rubber pivot bush flexes.
Hi Tim
Any ideas for the Bolts and lock Tabs for UJ to rear wheel, the High Tensile Bolts stretch, what do you Racers do other than wire tie the Nuts, anything to stop the stretching?
Thank you TimI’m just using a new set of standard bolts and lock tabs. Will see how it goes. There’s probably an ARPbolt that could be used that maybe stronger don’t know.
I use threadlock for a lot of things. Loctite 248 comes in a stick so is easy to use and can be broken with heat if needed.
