C3 Race Car Build
After adjusting the doors again and a lot playing I think I’m happy with the hood surround. Fingers crossed will bond it on at the weekend.
Is that the original Hood surround or a new one - if it is a new one (which it looks) is the Headlight Support Bar Riveted or not? This is a question a lot of owners ask, It must be bonded in, but the question of Rivets?
It’s a new surround and just bonded.
Being a 1969 the original was bonded and riveted. They changed to just bonded some point later in production but I don’t know when.
Headlight frames trial fitted.
Strengtheners fitted to the front panel
and painted
Heater hole covered
and foot vents covered but with a little vent added for a bit of breeze.
Tim, if you drive it as well as you have made it - You will have made it!
Great build thank you for sharing with us and taking the time.
My spannering is definitely better than my driving.
Where do you buy the covered heater hole?
I just made it from 1.5mm aluminium. It’s just a flat plate riveted to the bulkhead. There’s another one you can’t see covering the fresh air inlet in the inner wing.
Wiper mechanism blasted, gradually removing the yellow overspray that was on everything!
Need to get it on so I can work out how to modify the wiper door as I’ve binned all the vacuum gubbins.
