What compression do you have?
Will you be doing the camshaft break-in procedure on start up?
It’s probably becoming an ”old thing” with the popularity of retro fit roller followers somewhat negating the need to break-in.It’s around 11-1. Yes. Always run cams in. People talk like it’s a new thing but I’ve been running cams in on everything I’ve built for 25 years.
Yes, Lucas Oils Break In 20/50It’s probably becoming an ”old thing” with the popularity of retro fit roller followers somewhat negating the need to break-in.
Are you using a running-in oil?
Far from being a 'new' thing - oddly going back a little further I'm not so sure people really bothered quite so much about the cam running-in procedure - probably didn't bother too much about valve springs or timing things-up correctly either.........It’s around 11-1. Yes. Always run cams in. People talk like it’s a new thing but I’ve been running cams in on everything I’ve built for 25 years.
I’ve got oil pressure and spark and it turns over nicely for a highish compression engine but the one thing I’ve not got is coolant as it’s not arrived yet. So twiddling my thumbs now.
That is one fantastic looking and sounding engine .![]()
Always a rewarding milestone Tim - congratulations! If not quite Brrrmm-Brrrmmm at least Brrmm!
Put me in mind of my own first start - of a V8 - a few years ago....
https://flic.kr/p/2m4S5gD
Even more productive first shot than yours perhaps - but then I have to admit, I didn't build the engine....![]()
