I take it you are just a little disappointed!
The hell is that?Front end looks something like one of those Mako 'pointed' nose conversion kits from the late 60's/early 70's
Gutted mate!Caught the edge with a screwdriver while trying to sort the t-top alignment
Is it a new Hurst shifter? - did it come with the alignment tool? - its only a nylon or plastic 'L' shaped rod that passes through all shifter plates before linkages are connected. A correctly sized drill bit would do the same job. Are the shifter rods around the correct way?First drive on the road, few things to sort. I’m finding the change from 3rd to 2nd very tricky. Hurst shifter, just constantly seem to be going all the way across to reverse, any thoughts?
Congrats on getting the car back on the road - a monumentous day![]()
......so how was it to drive? (other than the shifter)
One of the very first things I did with mine (all those years ago) was to swap-out the worn-out stock shifter for the Hurst. I had similar issues to you. Chalk and Cheese. One of the things I like is the adjustable HD bolts used to limit shifter throw. Probably important for race use as you can shift as hard as you like knowing that the bolts will take the abuse (I wouldn't be confident that the stock shifter would cope so well) Shifting 'quality' was vastly improved. Just make sure that the individual shifter arms that are affixed to the selector shafts are 'tight' with no 'slop' - these are case hardened but can wear reducing shifter accuracy a little.No it’s an original shifter. Alignment is fine, I set it with a drill bit. That’s not the bit I’m finding tricky. I find it very easy to go beyond the spring tension for first/second and all the way towards the left for reverse.
Wow that looks amazing Tim. Hope I get a chance to see it up close.
And it's Blue.
Cheers Roger.
love how this car looks ,well coolFirst drive on the road, few things to sort. I’m finding the change from 3rd to 2nd very tricky. Hurst shifter, just constantly seem to be going all the way across to reverse, any thoughts?
It looks great! That's going to be sooo different from the Mini once you get to a race track
Are you planning on road miles to get accustomed, or tack to a track day or similar.
I remember many years ago now, talking to Olly Gavin about the noise in the old C5R GT1 - a story he later put in print somewhere. Other drivers always asked why the Corvette pilots couldn't hear them approaching from behind and he always laughed and asked them if they had ever driven a C5R.... He used to be "deaf" for days afterwards!
