Is it just the angle of your photo,
as the back side of Targa top seems to sit lower than the B pillar ?
What is happening with the cooling symptom-wise?
Your expansion tank is pressurised presumably then. Hopefully the small hose will do the trick.
Did you put a bypass hole in thermostat?
I am after some of these for my 78 but over a three month delay at the momentI understand what you mean. Just fitted these to my 71, all the precision of modern digital gauges but retaining the classic look. View attachment 7589View attachment 7590
I am after some of these for my 78 but over a three month delay at the moment![]()
Glad to see an update, I was starting to get worried about you, thought you might have lost your enthusiasm for the build.
HI HOW DID YOU REMOVE PAINT ?Started stripping paint, bored nowit’s had a shunt in the left rear at some point that’s going to need a repair and it’ll need a new front lower valance. It seems to have been sanded to fibreglass previously and the yukky yellow put on top of high build primer. There’s the odd places you can see the original silver.
