@teamzr1 Too much technology too many complications.
James
My C3 Corvettes were lucky to get 10 MPG and that was with less than 200 flywheel HP
It was those bad smog years that sparked the technology age and has been growing since the 1984 came out
Each year it got more complex but still due to smog and fuel mileage laws caused the electronics to take over and make performance gains
My 1999 C5 stock was like 350 flywheel HP ( about 15% loss over drivetrain)
I have a garage full of hand tools over the last 55 year but most of them are useless today
With the work I did to the '99 an example of what is done by wrenching would not have been much of a success without
knowing the electronics age.
Look at the load bearing chassis dyno results after my work which was greatly affected by knowledge of today's vehicles and that
is making the mods work together by tuning the controllers
So that is at rear wheels my 99 C5 runs up to 600 HP/Tq and that is at the rear wheels
And even with a 3.73 rear end gear, I can get 30 MPG on highway if I drive it normal
That's the problem, this has been around since mid 1980s, but people are not bothering how this all works and adapt to it
C3 days people had to play around with carb jet sizes, today AFR changes are done in a couple of minutes of tuning the engine controller
so it commands the fuel injector less or more dependent on what I see by using a OBD-II scanner and the data that PCM controller reports
Wrenching cannot fix changes, esp when getting complex
Example is I can tune almost any GM vehicle that uses a gas engine such as a guy in the Middle East put a supercharger on a C6 Corvette
and in that high heat.
Vette of course ran like total crap and close to blowing the engine to hell
He contacted me and within 2 hours I was able to cook up a custom tune and I tuned him via emails !
And the C6 ran great with the tune
So complex can be good, it just means people have to learn about this or go to people like me that understand the bits and bytes
I have taught all about this at a local college and these students worked in the vehicle repair business and most of them did not
know what I was talking about and when asked how they fixed customers' vehicle problems, the common answer was they threw parts at
it until the problem went away but if the used today's tools the scanner would have told them what the problem was in like 10 minutes
