Be interesting to see if using a Dba sound meter what level is at a right angle of exhaust tip and also in the cabin area
Maybe the shift linkage needs adjusting, quality and level of tranny fluid, or a synchro issue ?
TBH mine jumps sometimes jumps out of 'first' on an 'extended' over-run. Its always done it - previous owner had the gearbox overhauled and it came to me like that. TBH its not so much of an issue for me being as its in first gear.......guess it would be if racing and looking for all the engine braking I could get.Box jumping wise. It is a Hurst. I’ve checked the linkage and the stops. They’re as they should be. If you put it in 3rd then remove the linkage it’s as far into gear as it’ll go.
Fluid is at the right level
Ive rebuilt the box and it’s mainly new. So either something is amiss with what I’ve done, I’ve missed something that was worn or the shift boot is pushing it out of gear. I’ve pulled the boot off and will see what happens.
Running no power brakes - and the fact that its a 3.08 rear end and theoretically can wind up to ver 70 mph in first gear does really mean that engine braking is/could be a helpful addition.......I just need to make sure I don't rely on engine braking in first........despite all that it makes you look an 'ass' to any onlookers!This is extended overrun too. I’m not sure if it’d happen racing as you’ll probably be down the gears quicker than that but it’s annoying and shouldn’t really do it.
My gearbox needs to come out. It began with jumping out of 2nd gear a couple of second after lifting off, just as you have. The problem has now developed though into becoming reluctant to change into second gear unless I double de-clutch. Pita. I’ve decided it must be synchro. Did you renew all the synchro rings?
