Bolted the gearbox up to the engine after work. without the clutch on so I can get at the input shaft.
There’s no play in the input shaft at all. So I pulled the output yoke off and there’s definite play in the mainshaft. Takes a bit of force to move it probably because the centre bearing is new and wasn’t evident without the box on the engine as I would have been moving the whole box. Fingers crossed that’s the gearbox issue. The bearing surface doesn’t look worn but it obviously moving in the input shaft. Ordered a new mainshaft, bearing and main/input rollers.
I got the torque rating of the clutch wrong it’s over 700ftlbs so no way it’s not man enough. Clutch wise I’m going for operator error at the mo, maybe not bedded in properly and a bit too much clutch slip. There’s no high spots and a lot of the visible bits seems to be impacted friction material. So going to clean it up and fit a ceramic paddle plate and see how it goes.
