Because of the position that a rack fits in it changes the angle of the steering tie rods in relation to the wishbones and can cause a significant increase in bump steer. The C3 has a less than optimal setup for bump steer to start off with and a rack can make it worse.
Cheers that is what I thought, some rack sets now come with the track rod ends with longer bolts (studs) and spacers to facilitate adjusting the angle of the tie rods
I had had a recent body off including installation of a steering rack and the Vette went to another but this time (so called Vette specialist) for some odd jobs, all of which, he either screwed up or failed to do and one of his cons was: "I know it is all new but one of your track rod ends was faulty, so I replaced it," he then showed me the one he allegedly had taken off, I Knew it was not mine because of the length of the bolt was short as per normal set up - I looked at him and smiled.
Your blessed you have the knowledge and capability to do it all yourself
You are certainly not lacking in your ability and for a new owner you certainly know your way around a C3
If I may ask, what is your back ground that has given you the understanding of what you are doing, engineering or just good "hands on" experience and in depth knowledge gained from preparing race cars ?
Great Thread thank you.
