Pedals are now in place along with the column mount.
Servo and master cylinder too, need some weight at the front to balance it out.
Trial fit the body to the chassis, only a trial fit as I need to drill the rear mount I replaced and have to gauge how to cut the floors to lower the seats and mount them directly to the chassis.
All fits and with everything measured, body off again
Floor cut, once the driver’s side is done and ive got a longer drill bit to put split pins in for the rear arm shins the body will go back on.
Got a new puller and the pitman arm just slide off, something I’d done must have loosened it.
