Eurovettes
look up ABS fixer in usa - I have used him many times
Wow John, that is great work! I thought those items were irreparable and I believe scrap ones are as rare as hen's teeth.
You could easily make a good living repairing them![]()
Me too, I have the EBCM internal fault code on my '98 Pace Car.I'll be watching this thread with great interest, I haven't done all grounds yet but I think the ECBM on mine is faulty. If it can be fixed I'd be a buyer of that service.
Cannot tell until Nick as the testpig (wonder who talked him into this
gets this EBTCM back and does a testcase if that fixes all ABS/TC issues
The job would be much easier if the car was local as that easy to make a fix, test, if not look for more to fix
Crap job of having to desolder old solder joints, stuff just does not want to melt easy
worse is when installing the board back onto the 16 pins that they all have to be exactly the same spacing to line up
to the 16 holes of the board and then solder it all back up and in all this not melting the plastic of both relays, the blue cap you see
and the 2 black connectors
Not sure who would want to do these all the time as I did a dumb shift moment with the shaft of desolder tool
