Twin Spal wired to a temp sender in the head - also good to have a separate switch to bring on if sender fails etc
No I am thinking just the twin fans, relays and the sender, mine is wired so also comes on when the AC is switched on. but thinking you will not be running AC somehowThanks. Have you got a control unit that goes with the temp sender to switch it on and off?
You probably know there are retro fit controllers that run fan(s) at variable speeds according to conditions like modern cars. Always good to fit separate toggle switch inside if you think your temp guage is showing too warm
Some of the 'privateers' were timed at 200 mph+ on the Mulsanne straight during the early 70'sCheers. Yep no AC but you might be surprised to know most modern closed race cars do run AC. They’re almost all power limited and ballasted anyway so there’s no real disadvantage. Your average historic race Corvette is probably 50 to 150 bhp (300 in some cases) up on a C7 GTE car and about 100kg lighter.
The Greenwood cars were 40mph faster down the Mulsanne straight in 1976 than the C7s were in 2019.
No disrespect for guys running twin electric fans but factory fan & shroud if fitted and working properly is quite a formidable piece of kit (I repeat - if installed and used correctly)
Doesn't an engine driven fan sap power?
Thank youYes to some extent but you have got a clutch on a C3 so it only uses it when necessary, electrical power has to come from the engine too but because electric fans turn off completely they’re more efficient.
Tim have you decided on brakes and wheels?
One thing I'm not happy about on C3's ... brakes or maybe lack of them... maybe its just me..Brakes will be the standard items. It had recon callipers all round when I bought it.
Wheels I’m thinking of Torq Thrusts.
Not just you Mike - me too - brakes earn the description 'brakes' (like they kinda slow the car down.......kinda) its just that they don't really make the grade compared with most current vehicles......One thing I'm not happy about on C3's ... brakes or maybe lack of them... maybe its just me..
