Went for a drive today. When cruising it's a similar volume to the old exhaust but a nicer tone. The old system used to drone a bit. When you put the pedal to the metal it sounds more like a machine gun! Performance wise it doesn't feel much different, if anything it accelerates a little slower. I've still got the original Quadrajet on the car, which I need to fit a new top gasket to anyway (when I stripped it down last year I noticed the gasket was a bit damaged but didn't have a spare at the time). Whilst I've got it opened I'll check the float height and the Adjustable Part Throttle setting, from what I've read they are the only simple changes you can make. You can't really put bigger jets in the late model Quadrajets, they already have big ones.For the sort of revs you were probably doing the manifolds might have made little difference. Perhaps go up a jet size in the secondaries or are you on a AFB/Edel?
I think it’ll mainly depend on what silencers you had on. If they were straight through or not.
It was all in the COMP MAGNUM CAM I selected for a 327 CI engine with long tube headers
LSA is only 110 so will be a choppy idle
Good power from 2,000 to 5,500 RPMs
Unfortunately I don't have a way to measure my AFR and as things seem to be going I could really do with one. I've always thought that my engine was unmolested, I got lots of history with the car and there's no mention of anything being done to the engine, plus all the original parts were still attached to it (even though several didn't actually work).You have access to a wideband O2 sensor to place into the end of the exhaust and AFR meter to measure ?
If using E5 or E10 gas, for non WOT I would adjust carb for non WOT at like 14.4:1 and for WOT like 12.5:1 AFR
Monitor for engine knock and adjust to reduce that with carb or timing
If a seller won't ship to the UK they will quite often ship free to an american address. If so it can be worth using MyUS. They will give you an address in the States to have the parts shipped to and then they send them on to you. Their business being solely shipping they can negotiate very favourable bulk rates with the major shipping services - check the rate for your package on their website. I've used them several times - they're very efficient and it's free to join. Even if the internal shipping in the States isn't free it can still be worth using MyUS.Unfortunately the only one of those websites that has the rods I need (K series 49 or 50) and that will ship to the UK is Quadrajetparts.com
www.woolfe.uk
That looks good, how does the import VAT get paid? I can't see any reference to it on their websiteIf a seller won't ship to the UK they will quite often ship free to an american address. If so it can be worth using MyUS. They will give you an address in the States to have the parts shipped to and then they send them on to you. Their business being solely shipping they can negotiate very favourable bulk rates with the major shipping services - check the rate for your package on their website. I've used them several times - they're very efficient and it's free to join. Even if the internal shipping in the States isn't free it can still be worth using MyUS.
Great - hope it goes smoothly for you. Where MyUS can be really useful is when you're buying from several different suppliers. If you get all your purchases sent to your US address MyUS will consolidate them into one shipment before sending them on. This can really save on international shipping costs.New jets and rods ordered from Quadrajetparts and being shipped to MyUS address in Florida for the princely sum of $8.20. MyUs will ship to me for $23.29, so a total cost of $31.49 rather than $72 direct from the supplier. Thanks Antijam.
