Something we just take for granted these days.
Yes, but in doing so it is a real pain in the ass to work with Corvette fuel tanks
Starting with the C5s, GM went with 2 plastic like 9 gallon tanks that are mounted low and then are connected with a transfer tube
Each tank has a fuel pump and float
Due to damage done by that fricking Ethanol like ruining the gas level electronics in the tank or even the pumps
I changed the left tank's fuel pump, the SOB is like 16 inches long and lay sideways
To get this sucker out and the float at the same time you either have to take the left rear suspension out, that means when done have to do a wheel alignment or as I did lots of swearing and snuck it out with just 2 inches of free space to get it out and then fight a new one in
Now imagine if you also had to do the same thing on right side pump
Worse starting with the C6s the tanks are mounted high and to do any internal tank repairs or gas leaks on ends of transfer tube you have to
take the whole ass end out to get to the fuel system !
