Just to throw some thoughts out
1. 1979 C3 had a
generator which has an internal regulator
2.
Not an Alternator
3. 1979 did not have electric coolant fans. So if someone converted to electric, possible then needing a different serpentine belt length ?
And one used it is not 100% length causing problems to pulley on generator, slower, faster, load on shaft bearing
4. At idle is pulley turning true & smoothly, belt not too loose or tight
5. as GM engineering specs ( I
attached at the bottom of this the full 140-page PDF)
regulator at 85 F deg temp puts out 13.8 to 14.8 volts
Are you reading that at the output of the regulator ?
6. Is it possible the regulator is faulty, like bad diode(s) ?
7. Possible past owner installed the wrong Generator model ?
8. Is battery installed meet the GM specs below ?
