For every action, there is a reaction and in this case the action is the EBCM trips the C1288 DTC
it has done so with 2 different SWPS, so to me, you're spending a lot of time on SWPS and unless both could have the
same failure then you're spending a lot of time looking what the real cause is
I posted yesterday the GM definition of the action of causing C1288 to trip and then the reaction to it
I suggest you reread that and break it down into detail
If in fact the EBCM is seeing an issue to trips that DTC then can prove the reaction which is when C1288 trips
does EBCM trip any of the 4 wheels brakes via the solenoids of ABS
You can prove or disprove that by clearing the code, then recording the PIDS I mentioned and see if any of the 4 wheels ABS solenoids as I show again with the PIDs I show here
Clearly it truly a reason EBCM action in tripping C1288 then the HOLD and Release PIDs would show that and which wheel(s) brakes, even slightly
IF EBCM does command ABS then I would look at the YAW sensor causing the action
IF EBCM does not command ABS when DTC trips than it now to me points to either a EBCM fault, or wiring or ground issues
Monitor the digital SWPS bias correction, Lateral accelerometer and Yaw PIDs to see what that bias data you have is.
As I mentioned and there were another members post I mentioned failures with EBCM as to cracked solder joints or the small relay, common failures
Both can be repaired by yourself or someone else.
1997 and 98 C5s have EBCM in the ass end, due to water splashing back there it caused lots of wiring, grounds and EBCM problems so much so that in 1999 as mine is GM moved the EBCM up front by steering rack
Another main issues are ground points and the electronics highly depend on good ground connections
Throughout the car is ground spice packs. This is where several grounds are spliced inside the ground pack
From the outside the pack might look nice and clean but when you pry the top off then find a fricking mess
as high corrosion so I would look at the ground splice pack that includes the grounds for EBCM, wheel speed sensors , etc
I maybe wrong, but the YAW sensor might be mounted under passenger seat, else behind dash
I will try today to take my 1999 for a testdrive and record all the PIDs I showed about, so you could compare mine with yours.
Splice pack good condition
But can be this bad inside
Looks like this mounted to frame, assure also the frame and mounting bolts is very clean and tight
