A bit like time they are taking to build the so called `Smart Motorway` lanes on the M1 around my way ! The Romans built roads all over Britain in half the time !In your dreams, it will never be finished
I wonder how many owners ever think to regularly clean out drain holes in bottom of doors , scuttles , and other drainage chanels on any of their cars . Always a recipe for corrosion , damp carpets , wet electrics etc . The MG ZT and similar Rover saloons were a real problem if the scuttle drains either of the windscreen weren`t kept clear . The void under the plastic cover filled with water and that is where the ECU is located . Fizz , bang , no go !!Water exits via a rubber tube from the outside of the ventilation box to the inner wheel arch. The vent box has a flap that is controlled by a vacuum actuator to allow air out of the cabin.
An interesting 'factoid' Chuffer. After reading Oneball's comments about Astro Ventilation I was confused about the vacuum actuator under the rear deck (non a/c cars only) -I wonder how many owners ever think to regularly clean out drain holes in bottom of doors , scuttles , and other drainage chanels on any of their cars . Always a recipe for corrosion , damp carpets , wet electrics etc . The MG ZT and similar Rover saloons were a real problem if the scuttle drains either of the windscreen weren`t kept clear . The void under the plastic cover filled with water and that is where the ECU is located . Fizz , bang , no go !!
Yes...... much like the fibre optic 'tell tale' for the lights on earlier C3's - all very nice when all connected and working as a talking point perhaps.......but if faulty do you bother to repair it?
Sure sounds a dumb idea , and what a long suck through a pipe from the manifold to the actuator in the back of the car ! I wonder how many of them actually worked and for how long ? The guy who came visiting in my street the other day in his Cadillac Coupedeville had fibre optic tell tails for front and rear lights . The rears were little pin point lights in the roof lining above rear bench seats so you can see them in the rear view mirror . He claimed they all worked too !An interesting 'factoid' Chuffer. After reading Oneball's comments about Astro Ventilation I was confused about the vacuum actuator under the rear deck (non a/c cars only) -and immediately thought "that's a 'weak' spot, theoretically that could create all sorts of issues - where the hell does the vacuum line run on my car"? -
Simple expanation - '68's don't have one - and simply rely on positive cabin pressure to active/open flaps under rear deck - kinda logical really.
So GM decide to complicate things with a vacuum activated override - why? - all a bit of a waste of time and gimic really - much like the fibre optic 'tell tale' for the lights on earlier C3's - all very nice when all connected and working as a talking point perhaps.......but if faulty do you bother to repair it?
I wouldn`t use a Karcher in that confined space if I were you , no telling what problems you might cause . Just take the grills out and use some elbow grease . Then use a length of single electrical wire to poke down the drain tubes to clear the crap out .I need to repair those fibre optics. I want to use a karcher to clear out the vents properly.
Have fun! At least you have done the worst part getting them outYou can probably work out what I'm planning to do to my 'Vette next.....
....but not until it gets a bit warmer in the garage!
Trust me, you'll soon get hot under the collar once you startThe worst feeling of wanting to work on the car but it being too cold...
Time to get the thermal undies on !!You can probably work out what I'm planning to do to my 'Vette next.....
Twasn't me Chuffer - the welding is Uncle Sams original best.Don`t you just love the quality of welding on C3`s . Looks like it`s done by a blind welder with only one arm !
PS . Apologies in advance if you welded those trailing arms yourself Antijam !
All the manufacturer will worry about is will it outlive the 1 year warranty we offer. If it does, it’s not down to us anymore.Don`t you just love the quality of welding on C3`s . Looks like it`s done by a blind welder with only one arm !
Im so glad Chuffer you mentioned the welding, I so wanted to say something but i thought it might be inappropriate. In Engineering we used to call that pigeon s**t weldingNot quite, the crusty old ones are still on there......
