Today I managed to change a fuse on my '71. So what you say?
Well, while fiddling around trying to get my cigar lighter to work (I don't smoke but the 12V socket is useful) I neglected to disconnect the battery and of course managed to blow the fuse. Not only does the fuse protect the lighter but also the clock, and since I've gone to a lot of effort to get a working clock, this was doubly annoying.
Still, no problem; I'll just whip the old fuse out and put a new one in. Easier said than done; the fuse is in the box high up under the left side of the dash and not only is a the box itself an access problem, the relevant fuse is the most inaccessible of the lot. It's the one arrowed blue below at the top left of the box....
...and while this shot may Indicate that access should be straightforward, believe me it's not.
I manage to winkle the blown fuse out with the trimmed down wooden end of a small paintbrush, but holding the replacement with two fingers in the necessary spot is impossible.
One finger I can get there, so after a bit of thought I come up with this solution. I strap the fuse to my forefinger with a small rubber band as shown below...
View attachment 16781View attachment 16782
....so now I can simply press the fuse into the holder, slide my finger back to release the rubber band and Hey Presto - job done!  Working clock and power socket again
(Memo to self - isolate battery before fiddling with electrics)
