It's about time I posted something so here's an update on the windscreen frame. With the summer weather (early in the month anyway) with us, car time has conflicted with many other things like garden upkeep, jobs on the house, footie etc. Not just chores but nice things too. Deferred birthday parties for example: enjoying the company of friends and thinking back to when someone would blow on the cake before you ate it.....
However, progress has been made. The windscreen frame pieces have been assembled, taken apart, adjusted, re-assembled etc. too many times to count to get everything to fit correctly. I had made a metal frame to simulate the windscreen and this was very useful but not quite as reassuring as using the real thing. So the old screen was cleaned and pressed into service to check the fit. Fortunately it did. The measurements I had taken earlier were also checked to make sure nothing had moved in the interim. I also replaced the appropriate brackets and fitted the T-Tops just in case that revealed anything else untoward.
New tabs were welded on the T-Top brace to upper frame connection on both sides to provide a stronger attachment. Drivers side....
View attachment 12098 View attachment 12099
and passenger...
View attachment 12100 View attachment 12101
Then the positions of the puddle welds was checked on both sides...
... before drilling and cleaning up the holes. I ended up increasing the diameter of most of these holes to increase the weld area/strength.
Much welding and grinding later, all was complete and looking ok. Gratifyingly, the stainless steel T-Top brace cover dropped on to the new frame with just the slightest pressure.
The final (for the time being) task was to coat the new metal with etch primer to keep the rust at bay whilst I attend to the lower windscreen frame. There are quite a few trim and other holes to be drilled in the upper windscreen frame at some point. Seam sealer will probably be used to aid rust prevention and then top coat. I'm assuming the birdcage was painted black (can anybody confirm?) but I will probably wait until the lower frame is finished to do this.
Must admit to being quite pleased with the result - it looks and feels really solid. It's taken two months to make the jigs, remove the old parts and fit the new - I'm sure somebody more experienced would have done it a lot quicker. However, it's also been good fun without too many traumas.
There's still lots to do - the front glass fibre moulding needs to be removed next so that I can repair the lower windscreen frame and hinge posts. All required parts are in my workshop, so hammer and chisel in hand I will try and split the required joins over the next week or two. I have done quite a bit of research on this (as I tend to do before starting anything) and it looks fairly daunting. Worse still, I can already see that someone has been there before.... Onwards and upwards.
