Keeping up momentum during the rain this week I stripped the heating and aircon casings. The casings have a large gap between them so I can't imagine the heating/air con was working very well when it was last used.
The heater side casing was cracked and broken around where the blower motor is mounted and required some repairs. I forgot to take a 'pre' picture but you can see the repair areas at 8 and 11 o'clock around the blower motor hole. A few layers of glass fibre dovetailed into the existing material seems to have worked ok.
The blower motor looked a bit sorry for itself but it actually works. Excuse me whilst I sit down for a minute.
The metal panel on the air con side had a large hole where the seal flange is spot welded on. You can just see the while paper showing through in the lower part. It extended about 2 inches up from there under the flange.
New metal was shaped and welded in to fill the hole...
Which required the use of one of these... which you don't get to use very often on a Corvette.
Hole filled in it and flange repaired they looked like this..
With the flange rivetted back in place, cleaned and painted it now looks a bit healthier ..
The (almost) complete blower assembly looks like this... The rubber pipe that goes from the heater plenum to the blower motor to keep it cool has perished so I'll need a section of 18mm I/D rubber pipe to join the two.
Whilst I wait for the new metal to arrive for the birdcage I'll strip the aircon evaporator assembly on the other side and see what lurks there.
